nu1mlock
Hi!
Inside I have a TP-Link EAP245 v3 and it gives me good enough speed inside. However, as soon as I go outside I have close to zero signal and it is impossible to do anything with my phone (browsing, video, music etc). I have an old TP-Link MR600 router in AP-mode that covers outside and another house, but it takes about one minute for my phone to switch over. Even with zero bars on the phone it is still connected to the old AP.
I'm not sure what I need to solve this issue.
At first I was planning on replacing the TP-Link MR600 router with two older models of TP-Link EAP245 (v1) and a controller to increase the signal for outside and the second house. However, I am not certain that is a good idea.
The older model of EAP245 (v1) does not seem to support "Fast Roaming", which might be what I need? If yes, I would need the newer version of EAP245 (v3). That isn't a problem itself, just twice as expensive and it would be cheaper to purchase for example a 3-pack Deco M5, or as much as one 3-pack and one 2-pack of Deco M5.
My router is an Edgerouter X and incoming connection is 1Gbit. I don't need especially high speed wirelessly as I connect those devices with a cable.
Thank you!
Thank you!
