Diversion Pihole with Diversion as fall back option?
gtqiiptzfsfcppfcs
Hello, I have been using diversion with skynet and unbound with great results. Recently I wish to add pihole as a primary adblocker (mostly because I need to quickly edit ban list/individual blocking etc.). And diversion as a fall back option in case it fails.
I installed the above using amtm and use the following setting for lan. Is it correct that all I need to do is to put pihole's ip under DNS Server 1? Would the router switch back to diversion (192.168.1.2) if it fails? Would I lose skynet and unbound functionality if I use the pihole as my DNS server? Thank you!
