PineApple Mk5 - Mini Review
sfx2000
Part of the Furniture
Decided to break this out, considered putting this over in the Wireless section, but since this is a very focused device...
Hardware:
Fairly similar to the TP-LINK MR2030 with a Alfa USB adapter built-in
SOC - Atheros AR9331 MIPS R24k integrated 802.11n Router/AP/Wifi (B/G/N 1*1:1)
Memory - 16MB Flash, 64MB DDR
CPU is clocked at 400MHz
WiFi:
PHY0 - mapped to AR9331
PHY1 - Realtek RTL8187L (MAC/BB) with RTL8225 B/G RF ASIC
The RTL8187 is a USB2 adapter, attached to the AR9331 via Alcor USB2 Hub chip, with the AR9331 as USB master
Ethernet - provided by AR9331 integrated switch - 10/100 fast ethernet
USB2 External Interface - for mass storage or 3G/4G WAN modem with current SW - conversely, with appropriate driver support, could break out another USB-Ethernet or USB-Wifi for 5GHz support
USB2 also breaks out an SD-Card (just SD-Card, not fully SDIO) for uSD (FAT/ExFAT only, no XHSD, so limited to 32GB or less)
UART/JTAG/I2S breakout via pins, TTL Serial for BusPirate, full JTAG support
Board shots below
MkV Software:
OpenWRT (Attitude Adjustment) with Hak5 package management (for 'infusions') and their custom WebGUI
root@172.16.42.1's password:
BusyBox v1.19.4 (2015-03-11 01:16:39 EDT) built-in shell (ash)
Enter 'help' for a list of built-in commands.
  .NN,
  .cxxdl'  xMMO  'cdxxl'
  .c0WMNk;,NMMW:,xXMMKo.
  ...:KMMMWMMMMWMMMXc...  .
  ,  .l0NMMMNXMMMMMMMMMMMMXNMMMWKl'  xWd
  ,0Wd  .':xNMMMMMMMMMMMMMMMMNkc'.  ;KM0'
  lWMo  .;dNMMMMMMMMMMMMMMWx:.  .l.  dMWc
  :WWo  oNd  .;xKWMMMMMMMMMMMMMMMMMMMMWXx:.  dWX:  dMW;
  ,NWo  oMW:  .. ..,lOXWMMMMMMMMMMWN0o;.. ..  cWMl  dMN'
  .XMx  oWN;  lc  .loooolcooclooool.  cXl  oMWc  kMK.
  oMW'  ,WMl  cMW:  lWMW0d:;cdd:;:o0WMWl  lMW:  OMW'  ,WMl
  0M0  xMX.  .XMd  .lo:.,dXMMMMMMXd,.:ol.  kMK.  'NMd  KMO
  NMd  KMk  lMN.  .;:xOxollccddcclloxOx:;.  'WM:  OM0  xMX
  WMo  .XMx  dMK  oNMMMMWOc;;ol;;cOWMMMMNo  .XMl  kMK  dMN
  NMx  0MO  :Kd. .lllcl;.:0WMMMMW0:.;lclll. .xK;  0MO  kMX
 __  ___ ______ _  _____ _.:W0;,oxl:::oOOo:::lxo,;0W:  _  .ONo  KMk
 \ \  / (_|  ____(_) |  __ (_);cKMMMMWk:.;,.;kWMMMMKc;.  | |  .OX:
  \ \  /\  / / _| |__  _  | |__) _ _ __  ___  __ _ _ __  _ __ | | ___  Mark V
  \ \/  \/ / | |  __| | | |  ___| | '_ \ / _ \/ _` | '_ \| '_ \| |/ _ \ 2.4.0
  \  /\  /  | | |  | | | |  | | | | |  __| (_| | |_) | |_) | |  __/
  \/  \/  |_|_|  |_| |_|  |_|_| |_|\___|\__,_| .__/| .__/|_|\___|.com
  With OpenWrt ATTITUDE ADJUSTMENT  | |  | |
  |_|  |_|
root@Pineapple:~# uname -a
Linux Pineapple 3.3.8 #81 Mon Aug 3 19:40:39 PDT 2015 mips GNU/Linux
dmesg output
root@Pineapple:~# dmesg
[  0.000000] Linux version 3.3.8 (sebkinne@buildtop) (gcc version 4.6.3 20120201 (prerelease) (Linaro GCC 4.6-2012.02) ) #81 Mon Aug 3 19:40:39 PDT 2015
[  0.000000] MyLoader: sysp=97d936c9, boardp=61b798de, parts=6238a85e
[  0.000000] bootconsole [early0] enabled
[  0.000000] CPU revision is: 00019374 (MIPS 24Kc)
[  0.000000] SoC: Atheros AR9330 rev 1
[  0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
[  0.000000] Determined physical RAM map:
[  0.000000]  memory: 04000000 @ 00000000 (usable)
[  0.000000] Initrd not found or empty - disabling initrd
[  0.000000] Zone PFN ranges:
[  0.000000]  Normal  0x00000000 -> 0x00004000
[  0.000000] Movable zone start PFN for each node
[  0.000000] Early memory PFN ranges
[  0.000000]  0: 0x00000000 -> 0x00004000
[  0.000000] On node 0 totalpages: 16384
[  0.000000] free_area_init_node: node 0, pgdat 802d8470, node_mem_map 81000000
[  0.000000]  Normal zone: 128 pages used for memmap
[  0.000000]  Normal zone: 0 pages reserved
[  0.000000]  Normal zone: 16256 pages, LIFO batch:3
[  0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[  0.000000] pcpu-alloc: [0] 0
[  0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 16256
[  0.000000] Kernel command line:  board=MK5 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
[  0.000000] PID hash table entries: 256 (order: -2, 1024 bytes)
[  0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[  0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[  0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[  0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[  0.000000] Writing ErrCtl register=00000000
[  0.000000] Readback ErrCtl register=00000000
[  0.000000] Memory: 61592k/65536k available (2124k kernel code, 3944k reserved, 406k data, 212k init, 0k highmem)
[  0.000000] SLUB: Genslabs=9, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[  0.000000] NR_IRQS:51
[  0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
[  0.080000] pid_max: default: 32768 minimum: 301
[  0.080000] Mount-cache hash table entries: 512
[  0.090000] NET: Registered protocol family 16
[  0.090000] gpiochip_add: registered GPIOs 0 to 29 on device: ath79
[  0.100000] MIPS: machine is MK5 V1.0
[  0.350000] bio: create slab <bio-0> at 0
[  0.360000] Switching to clocksource MIPS
[  0.360000] NET: Registered protocol family 2
[  0.370000] IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
[  0.370000] TCP established hash table entries: 2048 (order: 2, 16384 bytes)
[  0.370000] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[  0.380000] TCP: Hash tables configured (established 2048 bind 2048)
[  0.390000] TCP reno registered
[  0.390000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[  0.400000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[  0.400000] NET: Registered protocol family 1
[  0.410000] PCI: CLS 0 bytes, default 32
[  0.430000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[  0.430000] JFFS2 version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[  0.440000] msgmni has been set to 120
[  0.440000] io scheduler noop registered
[  0.450000] io scheduler deadline registered (default)
[  0.450000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[  0.460000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11) is a AR933X UART
[  0.470000] console [ttyATH0] enabled, bootconsole disabled
[  0.480000] m25p80 spi0.0: found w25q128, expected m25p80
[  0.480000] m25p80 spi0.0: w25q128 (16384 Kbytes)
[  0.490000] 5 tp-link partitions found on MTD device spi0.0
[  0.490000] Creating 5 MTD partitions on "spi0.0":
[  0.500000] 0x000000000000-0x000000020000 : "u-boot"
[  0.510000] 0x000000020000-0x000000102758 : "kernel"
[  0.510000] mtd: partition "kernel" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[  0.520000] 0x000000102758-0x000000ff0000 : "rootfs"
[  0.530000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[  0.540000] mtd: partition "rootfs" set to be root filesystem
[  0.550000] mtd: partition "rootfs_data" created automatically, ofs=CD0000, len=320000
[  0.550000] 0x000000cd0000-0x000000ff0000 : "rootfs_data"
[  0.560000] 0x000000ff0000-0x000001000000 : "art"
[  0.570000] 0x000000020000-0x000000ff0000 : "firmware"
[  0.590000] ag71xx_mdio: probed
[  0.590000] eth0: Atheros AG71xx at 0xb9000000, irq 4
[  1.150000] ag71xx ag71xx.0: eth0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
[  1.160000] TCP cubic registered
[  1.160000] NET: Registered protocol family 17
[  1.160000] Bridge firewalling registered
[  1.170000] 8021q: 802.1Q VLAN Support v1.8
[  1.180000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
[  1.190000] Freeing unused kernel memory: 212k freed
[  3.530000] Registered led device: mk5:red:wlan1
[  3.530000] Registered led device: mk5:blue:wlan0
[  3.530000] Registered led device: mk5:amber:lan
[  6.860000] JFFS2 notice: (421) jffs2_build_xattr_subsystem: complete building xattr subsystem, 4 of xdatum (1 unchecked, 3 orphan) and 31 of xref (0 dead, 16 orphan) found.
[  7.810000] SCSI subsystem initialized
dmesg output (continued) - note the USB support...
[  8.120000] usbcore: registered new interface driver usbfs
[  8.120000] usbcore: registered new interface driver hub
[  8.130000] usbcore: registered new device driver usb
[  8.670000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[  8.680000] ehci-platform ehci-platform: Generic Platform EHCI Controller
[  8.690000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
[  8.720000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
[  8.740000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
[  8.740000] hub 1-0:1.0: USB hub found
[  8.740000] hub 1-0:1.0: 1 port detected
[  8.850000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[  8.970000] uhci_hcd: USB Universal Host Controller Interface driver
[  9.100000] Initializing USB Mass Storage driver...
[  9.100000] usbcore: registered new interface driver usb-storage
[  9.110000] USB Mass Storage support registered.
[  9.150000] usb 1-1: new high-speed USB device number 2 using ehci-platform
[  9.300000] hub 1-1:1.0: USB hub found
[  9.300000] hub 1-1:1.0: 4 ports detected
[  9.580000] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[  9.800000] usb 1-1.4: new high-speed USB device number 4 using ehci-platform
[  9.930000] scsi0 : usb-storage 1-1.4:1.0
[  10.930000] scsi 0:0:0:0: Direct-Access  Multi  Flash Reader  1.00 PQ: 0 ANSI: 0
[  11.470000] sd 0:0:0:0: [sda] 3907584 512-byte logical blocks: (2.00 GB/1.86 GiB)
[  11.470000] sd 0:0:0:0: [sda] Write Protect is off
[  11.480000] sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
[  11.480000] sd 0:0:0:0: [sda] No Caching mode page present
[  11.480000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  11.490000] sd 0:0:0:0: [sda] No Caching mode page present
[  11.500000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  11.510000]  sda: sda1 sda2
[  11.510000] sd 0:0:0:0: [sda] No Caching mode page present
[  11.520000] sd 0:0:0:0: [sda] Assuming drive cache: write through
[  11.520000] sd 0:0:0:0: [sda] Attached SCSI removable disk
[  22.220000] eth0: link up (100Mbps/Full duplex)
[  29.540000] eth0: link down
[  33.060000] Loading modules backported from Linux version master-2014-01-23-0-g62c147d
[  33.070000] Backport generated by backports.git backports-20140124-0-g1256d3e
[  33.180000] cfg80211: Calling CRDA to update world regulatory domain
[  33.190000] cfg80211: World regulatory domain updated:
[  33.190000] cfg80211:  DFS Master region: unset
[  33.200000] cfg80211:  (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[  33.200000] cfg80211:  (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[  33.210000] cfg80211:  (2457000 KHz - 2482000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[  33.220000] cfg80211:  (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[  33.230000] cfg80211:  (5170000 KHz - 5250000 KHz @ 80000 KHz), (300 mBi, 2000 mBm)
[  33.240000] cfg80211:  (5735000 KHz - 5835000 KHz @ 80000 KHz), (300 mBi, 2000 mBm)
[  33.240000] cfg80211:  (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm)
[  34.790000] usbcore: registered new interface driver rt73usb
[  34.850000] ath: phy0: Enable LNA combining
[  34.850000] ath: EEPROM regdomain: 0x0
[  34.850000] ath: EEPROM indicates default country code should be used
[  34.850000] ath: doing EEPROM country->regdmn map search
[  34.850000] ath: country maps to regdmn code: 0x3a
[  34.850000] ath: Country alpha2 being used: US
[  34.850000] ath: Regpair used: 0x3a
[  34.860000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
[  34.860000] Registered led device: ath9k-phy0
[  34.860000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
[  34.890000] cfg80211: Calling CRDA for country: US
[  34.890000] cfg80211: Regulatory domain changed to country: US
[  34.890000] cfg80211:  DFS Master region: FCC
[  34.900000] cfg80211:  (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[  34.910000] cfg80211:  (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2700 mBm)
[  34.910000] cfg80211:  (5170000 KHz - 5250000 KHz @ 80000 KHz), (300 mBi, 1700 mBm)
[  34.920000] cfg80211:  (5250000 KHz - 5330000 KHz @ 80000 KHz), (300 mBi, 2400 mBm)
[  34.930000] cfg80211:  (5490000 KHz - 5600000 KHz @ 80000 KHz), (300 mBi, 2400 mBm)
[  34.940000] cfg80211:  (5650000 KHz - 5710000 KHz @ 40000 KHz), (300 mBi, 2400 mBm)
[  34.950000] cfg80211:  (5735000 KHz - 5835000 KHz @ 80000 KHz), (300 mBi, 3000 mBm)
[  34.950000] cfg80211:  (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 4000 mBm)
[  35.240000] ieee80211 phy1: Selected rate control algorithm 'minstrel_ht'
[  35.240000] ieee80211 phy1: hwaddr <snip>, RTL8187vB (default) V1 + rtl8225z2, rfkill mask 2
[  35.270000] rtl8187: Customer ID is 0x46
[  35.270000] Registered led device: rtl8187-phy1::radio
[  35.270000] Registered led device: rtl8187-phy1::tx
[  35.270000] Registered led device: rtl8187-phy1::rx
[  35.280000] rtl8187: wireless switch is on
[  35.280000] usbcore: registered new interface driver rtl8187
[  35.370000] Button Hotplug driver version 0.4.1
[  35.580000] RPC: Registered named UNIX socket transport module.
[  35.590000] RPC: Registered udp transport module.
[  35.590000] RPC: Registered tcp transport module.
[  35.600000] RPC: Registered tcp NFSv4.1 backchannel transport module.
[  35.920000] PPP generic driver version 2.4.2
[  35.960000] usbcore: registered new interface driver rt2800usb
[  36.090000] tun: Universal TUN/TAP device driver, 1.6
[  36.090000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[  36.440000] ip_tables: (C) 2000-2006 Netfilter Core Team
[  36.670000] NET: Registered protocol family 24
[  36.820000] nf_conntrack version 0.5.0 (965 buckets, 3860 max)
[  37.520000] xt_time: kernel timezone is -0000
[  38.050000] usbcore: registered new interface driver ath9k_htc
[  38.090000] usbcore: registered new interface driver cdc_acm
[  38.100000] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[  38.320000] usbcore: registered new interface driver usbserial
[  38.330000] USB Serial support registered for generic
[  38.330000] usbcore: registered new interface driver usbserial_generic
[  38.340000] usbserial: USB Serial Driver core
[  38.480000] usbcore: registered new interface driver asix
[  38.550000] usbcore: registered new interface driver cdc_ether
[  38.790000] Error: Driver 'gpio-keys-polled' is already registered, aborting...
[  38.900000] usbcore: registered new interface driver rndis_host
[  39.010000] sd 0:0:0:0: Attached scsi generic sg0 type 0
[  39.030000] USB Serial support registered for GSM modem (1-port)
[  39.040000] usbcore: registered new interface driver option
[  39.040000] option: v0.7.2:USB Driver for GSM modems
[  39.060000] USB Serial support registered for pl2303
[  39.070000] usbcore: registered new interface driver pl2303
[  39.070000] pl2303: Prolific PL2303 USB to serial adaptor driver
[  46.780000] FPU emulator disabled, make sure your toolchainwas compiled with software floating point support (soft-float)
[  48.670000] device eth0 entered promiscuous mode
[  49.500000] eth0: link up (100Mbps/Full duplex)
[  49.500000] br-lan: port 1(eth0) entered forwarding state
[  49.510000] br-lan: port 1(eth0) entered forwarding state
[  51.510000] br-lan: port 1(eth0) entered forwarding state
[  56.310000] device wlan0 entered promiscuous mode
[  56.420000] br-lan: port 2(wlan0) entered forwarding state
[  56.510000] device wlan0-1 entered promiscuous mode
[  57.250000] br-lan: port 3(wlan0-1) entered forwarding state
[  57.260000] br-lan: port 3(wlan0-1) entered forwarding state
[  58.420000] br-lan: port 2(wlan0) entered forwarding state
[  59.260000] br-lan: port 3(wlan0-1) entered forwarding state
[  73.140000] wlan1: authenticate with <snip>
[  73.440000] wlan1: send auth to <snip> (try 1/3)
[  73.440000] wlan1: authenticated
[  73.470000] wlan1: associate with <snip> (try 1/3)
[  73.480000] wlan1: RX AssocResp from <snip> (capab=0x1431 status=0 aid=1)
[  73.480000] wlan1: associated
more stuff
 lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 058f:6254 Alcor Micro Corp. USB Hub
Bus 001 Device 003: ID 0bda:8187 Realtek Semiconductor Corp. RTL8187 Wireless Adapter
Bus 001 Device 004: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
/proc/cpuinfo
system type     : Atheros AR9330 rev 1
machine       : MK5 V1.0
processor     : 0
cpu model     : MIPS 24Kc V7.4
BogoMIPS     : 265.42
wait instruction   : yes
microsecond timers   : yes
tlb_entries     : 16
extra interrupt vector   : yes
hardware watchpoint   : yes, count: 4, address/irw mask: [0x0000, 0x0f00, 0x0080, 0x0820]
ASEs implemented   : mips16
shadow register sets   : 1
kscratch registers   : 0
core       : 0
VCED exceptions     : not available
VCEI exceptions     : not available
