connmon ping frequency settings doesn't seem to work?
LaMpiR
Hi.
I have AX88U with latest firmware from Merlin as well as latest connmon v3.0.2 but I had some problems with my ISP and I have tried to change the settings for ping to get a more regular readout. Setting to every 26min or so, then 1 hour, then 2 hours had no impact on when the ping would perform.
Every day
Mode: Every X hours/minutes
I am stuck from my previous setting and ping timer is working only 00:29 once per day even though I had it every 29 minutes or so.
Did anyone else have this problem maybe?
Are you trying to set the value via the GUI or CLI?
and can you post a copy of the config file from /jffs/addons/connmon.d or /opt/share/connmon.d , redacting any login information for any notification methods you use?
is the setting showing in the GUI as what you set it to even after a refresh, or is it reverting to the last value?
It's showing the value which I have set. I've changed to 23 minutes, left for a day or two, went back, it shows 23 but test are not that in that time range. Same goes for 1 hour, 2 hours and so on.
This is from /opt/share/connmon.d/config file. I have modified it to 2 hours.
PINGSERVER=195.xxx.xxx.xxx
OUTPUTTIMEMODE=non-unix
STORAGELOCATION=usb
PINGDURATION=60
AUTOMATED=true
SCHDAYS=*
SCHHOURS=*/2
SCHMINS=0
DAYSTOKEEP=365
LASTXRESULTS=50
EXCLUDEFROMQOS=true
NOTIFICATIONS_EMAIL=false
NOTIFICATIONS_WEBHOOK=false
NOTIFICATIONS_PUSHOVER=false
NOTIFICATIONS_CUSTOM=false
NOTIFICATIONS_HEALTHCHECK=false
NOTIFICATIONS_INFLUXDB=false
NOTIFICATIONS_PINGTEST=None
NOTIFICATIONS_PINGTHRESHOLD=None
NOTIFICATIONS_JITTERTHRESHOLD=None
NOTIFICATIONS_LINEQUALITYTHRESHOLD=None
NOTIFICATIONS_PINGTHRESHOLD_VALUE=30
NOTIFICATIONS_JITTERTHRESHOLD_VALUE=15
NOTIFICATIONS_LINEQUALITYTHRESHOLD_VALUE=75
NOTIFICATIONS_EMAIL_LIST=
NOTIFICATIONS_HEALTHCHECK_UUID=
NOTIFICATIONS_WEBHOOK_LIST=
NOTIFICATIONS_PUSHOVER_LIST=
NOTIFICATIONS_PUSHOVER_API=
NOTIFICATIONS_PUSHOVER_USERKEY=
NOTIFICATIONS_INFLUXDB_HOST=
NOTIFICATIONS_INFLUXDB_PORT=8086
NOTIFICATIONS_INFLUXDB_DB=connmon
NOTIFICATIONS_INFLUXDB_VERSION=1.8
NOTIFICATIONS_INFLUXDB_USERNAME=
NOTIFICATIONS_INFLUXDB_PASSWORD=
NOTIFICATIONS_INFLUXDB_APITOKEN=
ok so the value is making it to the config file and saving, that's good.
can you share the output of this command please?
cru l | grep connmon
Here is the problem :)
user@router:/tmp/mnt/skynetusb/entware/share/connmon.d# cru l | grep connmon
28 */0 * * * /jffs/scripts/connmon generate #connmon#
try running
cru d connmon
and then running a ping test
Thank you. I have checked with "cru l | grep connmon" and got this output
0 */2 * * * /jffs/scripts/connmon generate #connmon#
How would I set it to run at some random time? For example every 2 hours and 23 minutes? Trying not to interfere with spdMerlin.
