Ping spikes to 5GHz wireless clients only (RT-AC68R - Merlin 40_alpha7)
IanEnc
[SOLVED] Ping spikes to 5GHz wireless clients only (RT-AC68R - Merlin 40_alpha7)
My apologies if this was address previously. I could not find anything relevant using the search.
I just set up my RT-AC68R yesterday.
Using my wired PC to the router, when I try to ping a client connected on the 5GHz network I get spikes and significant packet loss.
Reply from 192.168.1.101: bytes=32 time=945ms TTL=64
Reply from 192.168.1.101: bytes=32 time=1ms TTL=64
Request timed out.
Reply from 192.168.1.101: bytes=32 time=1035ms TTL=64
Reply from 192.168.1.101: bytes=32 time=2ms TTL=64
Request timed out.
Reply from 192.168.1.101: bytes=32 time=1254ms TTL=64
Request timed out.
Reply from 192.168.1.101: bytes=32 time=1103ms TTL=64
Request timed out.
This goes on and on.
I get the same type of spikes if I use the Network Tools in the ASUS GUI to ping the wireless client.
When I ping the wired PC from the wireless client I get constant latency between 1ms - 3ms, with some spikes to 1000ms or more, and very little time outs.
When I connect the wireless client to the 2.4GHz frequency on the router, I no longer get this issue.
5GHz settings:
N + AC Only
Channel Bandwish set to 20 / 40 / 80MHz
Channel 161
My throughput between the wired PC and the wireless PC averages around 160Mbps (20MB/s). I find that accessing shared folders from one PC to the other can lag quite a bit before the folder is opened, which I would assume is because of what is causing the lag spikes.
There are no other 5GHz networks in the area as per inSSIDer. I have tried to disable the software firewall on my clients to see if that is the issue, but the spikes remain. (Plus I do not think the firewall can distinguish the difference between a 2.4GHz wifi connection and a 5GHz connection).
Has anyone experienced this so far? If so, I would appreciate your input.
When I return home I plan to try the following:
- Move router to another location to see if my DSL modem could be interefing with the 5GHz frequency (shot in the dark, since wireless is disabled on the modem and it is set to bridge mode only).
- Try another 5GHz Channel
- Try another firmware if the above fails.
The issue appears to have been resolved.
I tried changing the wireless adapter drivers on the wireless client. This caused the 5GHz antennae to stop working for some reason. I reverted back to the previous driver, and now there are no ping spikes.
