Please help and Critique my G \ N Network Setup
  • Thread starter Thread starter SpeedyVV
  • Start date Start date
S
SpeedyVV
Guest
Hello networking folks:
I have a home network setup that has 2 WiFi Router\Switches\Gateways (not sure what is what):
  1. A 2Wire 2701HG-G Gateway provided by my ISP (Bell Sympatico)
  2. A D-Link DIR 655 that I bought
Question 1: The reason I have a second router is because I want to seperate my G and my N devices\clients. Does this make sense?
Question 2: I also wanted a fast Gigabit network for my Windows Home Server. I think this makes sense right?
So here is how my network is setup:
So everything is on 1 network: 192.168.2.0
DHCP services are provided by the 2Wire router @:192.168.2.1
I also have the Family PC (192.168.2.61),on the 2Wire Router.
The reason for this is because the Family PC is on another floor and I had could only fish Cat5 to the 2Wire Router.
Also, I am running out of ports on the D-Link Router for things that need the highest connection to the Windows Home Server.
Question 3: Why does the Family PC have problems being backed up by the Windows Home Server? It is the only one with this problem.
Question 4: Does this seem to be a good\optimal setup for my home network?
I have included the info for both routers below.
All help is appreciated.
You have done a nice job of setting up your network.
Separating 11g and draft 11n is the right way to go. Make sure the DIR-655 is set to 20MHz channel mode and a different channel than the 2wire (1, 6, or 11).
Gigabit is a good choice for the WHS machine. Does the 2Wire also have a gigabit switch?
For Question 3, I need to know the nature of the problem with the backup.
As far as running out of ports, just uplink a gigabit switch to the DIR-655 to add ports.
Thanks for the reply.
Is this a good option for the gigabit switch?
http://www.dlink.com/products/?pid=494
Great. Thanks so much for your help.
The 2Wire router only has 100Mb, and 802.11G. That is the 1st reason why I bought the D-Link DIR 655.
While researching the nature of the backup problem, I noticed the log files mentioned something to do with the Parental Control software. I'll tinker with that to see if I can fix it.
BTW, I just noticed that you were the author of the article that I based my original setup.
Thank you very much for that great article. It saved me tons of time.
Here is the final setup plan I came up with:
