GabrielPhoto
Hi!
So I have the following
AXE-16000 (office) as my main router
AXE-11000 in my basement and hardwired to one output from a Switch hardwired to the AX-16000 (office)
AX-11000 in my garage not hardwired.
I was going to replace the AX-11000 with another AXE-11000 but after reading this article it would seem that it is not hurting anything?
https://dongknows.com/asus-tri-band-routers-gt-ax11000-vs-gt-axe11000/#comments
Or do you have some suggestions on how to best implement them?
I was going to grab a cheaper model to use as AP in my basement to create a dedicated 2.4 for my smart bulbs that are having issues connecting.
So I figured I would ask for suggestions on how to improve my mesh with the above gear or if I should remove, or add anything else.
Thanks!
Thanks!
