Please help me set up a VPN connection via WireGuard VPN
muzykcb
Hello.
I have a connection via WireGuard VPN but I can't connect to the disk connected to the router
- in the previous software from the 3.0.0.4.388 series ... there were no problems in the software: 3.0.0.6.102 .... there are problems (it is possible that I have something set incorrectly because I do not see the option to keep a password and login)
- OPENVPN worked without problems and connects remotely to the disks
RT-BE86U
This helps or not ? And you mean can't connect to the "samba/homecloud" disk from Wan ? Check samba settings ?
Kind regards
