Policy based routing (manual method) - but with 2 VPNs?
wizin
RT-N66U with latest Merlin Build
So I got it working after following wiki - https://github.com/RMerl/asuswrt-merlin/wiki/Policy-based-routing-(manual-method)?
Now say I want to setup Client 2 with another country location and want a particular device to use that, how would I go about that
Instructions are basically assuming Client 1
This is the code
#!/bin/sh
sleep 2
for i in /proc/sys/net/ipv4/conf/*/rp_filter ; do
echo 0 > $i
done
ip route flush table 100
ip route del default table 100
ip rule del fwmark 1 table 100
ip route flush cache
iptables -t mangle -F PREROUTING
ip route show table main | grep -Ev ^default | grep -Ev tun11\
| while read ROUTE ; do
ip route add table 100 $ROUTE
done
ip route add default table 100 via $(nvram get wan_gateway)
ip rule add fwmark 1 table 100
iptables -t mangle -A PREROUTING -i br0 -j MARK --set-mark 1
iptables -t mangle -A PREROUTING -i br0 -m iprange --src-range 192.168.x.xxx -j MARK --set-mark 0
exit 1
This is the code
#!/bin/sh
sleep 2
echo 0 > $i
done
done
exit 1
The easiest way is to assign a static IP to the device based on mac address. In the OpenVPN Client tab, set Redirect Internet Traffic to "Policy Rules". Then, enter the IP of the device you assigned, 0.0.0.0 for destination IP and VPN for iface.
