Port based selective routing
canufrank
I have a machine behind my router that is routed through the VPN tunnel. I would like certain traffic to use the WAN, but am failing to implement the solutions I've seen outlined in various threads. As a precursor, some threads utilize --dports while others use --sports in their listing.
In its simplest form, my script looks like
TAGMARK=16;   MYNAS=192.168.0.46;   PORTDIR=sports
ip rule add from $MYNAS  fwmark $TAGMARK table main prio 999
iptables -t mangle -I PREROUTING -i br0 -s $MYNAS -p tcp -m multiport --$PORTDIR 80,443 -j MARK --set-mark $TAGMARK
However, if I run { curl checkip.dyndns.com; } on MYNAS, I get the external (public) IP of the VPN tunnel.
<html><head><title>Current IP Check</title></head><body>Current IP Address: 172.98.67.46</body></html>
So, trash that rule, add with --dports and flush cache. Now curl times out on MYNAS:
curl: (7) Failed to connect to checkip.dyndns.com port 80: Connection timed out
So, I think that's telling me that dports is the correct syntax. It also tells me that I'm missing something. By default the 2nd rule in filter/FORWARD is
iptables -L FORWARD 2 -vn
Chain FORWARD (policy DROP 0 packets, 0 bytes)
 pkts bytes target  prot opt in    out  source     destination
11187 3840K ACCEPT  all  --  *     *    0.0.0.0/0  0.0.0.0/0  state RELATED,ESTABLISHED
    0    0  ACCEPT  all  --  tun11 *    0.0.0.0/0  0.0.0.0/0
(The INPUT chain has the same rule in position 1.) So, I don't know where this traffic is being stopped.
