blacksheep
Running Merlin firmware v384.10 on an ASUS RT-AC3200.
I have never had an issue with this before and I've been running this firmware for some time.
TL;DR: Can I manage port forwarding via the routers' ssh terminal?
I added a new computer to my network.
I installed plex media server and successfully updated port forwarding for Plex in the AC3200 Virtual Server/Port Forwarding Tab GUI (inside the WAN tab).
I also have installed Apache to serve my web pages but the Virtual Server/Port Forwarding GUI fails to update or delete that port forwarding assignment.
I am connected to the router through a SSH connection.
I was hoping there was a command I can run in the terminal of the router and adjust that obsolete port forwarding assignment.
I need to remove 192.168.1.143 forwarding to port 80
I need to add 192.168.1.92 to forward to port 80
I found nat_rules_eth0_eth0 and redirect_rules inside the tmp folder but I don't know if that is where I need to make the adjustment AND whether that change will stick through a reboot.
I tried to change those but the change is not reflected in the GUI.
