Port forwarding VPN on a dual WAN ASUS merlin AC66U
manwdaplan
So I have a ASUS AC66U with Merlin installed 372.42. I have a Windows RAS setup with PPTP on port 1723. I setup port forwarding to the RAS server. I can connect with PPTP and it works great for about 20 mins. Then I disconnect and can not connect again for about 20 or 30 mins. Then it works again and so on and so forth. I feel like has something to do with the dual WAN. Its setup for round robin 1 to 1. Is there any way to set to use only one WAN for incoming port forwarding and stick to that WAN? Or should I just go ahead and set it for fail over (fail over was not working well when I had it setup before)
