S
s333allnetbuilder
Guest
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Description=Port+Multiplier
These Port Multiplier Enclosure cost $250+ for a 4bay.
From what I see it is just a small metal case with fans and a mini power supply.
Basically, lets you externally house your SATA drives that normally would be inside the PC case.
A generic regular computer case is way cheaper than this.
Why is it so expensive? Any cheaper alternatives?
