night_chrono
I have an RT-AX88U running merlin 386.1 (but this problem existed on the 384.X versions too.) I am on AT&T fiber with their BGW210-700 modem in bridge mode. I opened ports 7777:7782 for several instances of an Unreal 3 game server I run. People can connect and play without issue. The issue I am having is every port scanner I have tried says the ports are closed. I want to use uptime robot to monitor my server, but it doesn't see the ports either. Port scanners see other ports I have open (like 27015 for my sourcemod server) but none of the ones in the range of my unreal server.
I have "Respond ICMP Echo (ping) Request from WAN" enabled in the firewall settings.
I have no idea if this is a merlin issue, an asus issue, or some other network topology issue that I can't find. I am hoping someone here has an idea.
Thanks to anyone who can help.
