Possible bug: SMB Simpler Share Naming
helloguys
RT-AC86U, Merlin 386.1_2.
After enabling "Simpler share naming", more and more smbd processes emerge on ps list. CPU spikes to 100%. After disabling the option, only one smbd process left. Everything back to normal. This is always reproducible. See screenshots below. (FYI, I did clean install: stock firmware > factory reset > Merlin > factory reset).
ColinTaylor
Part of the Furniture
Have you tried rebooting your PC(s)? It's possible that they're remembering to old pathname and repeatedly trying to connect to it.
maxbraketorque
Simpler sharing is working fine on my AC86U with 386.1_2 with two USB drives. One drive has two ext4 partitions and the other has three ext4 partitions. (Thanks ColinTaylor for making that easy to setup.)
helloguys
So if a SMB client keeps trying the "wrong path", it will create a DoS attack and eventually bring down the router?
Anyway, I restarted the PC and re-enabled the "Simpler share naming" option. See how it goes. Thanks!
