Possible to change dnsmasq settings without Merlin
legend
I'm using official ASUS firmware, if I don't flash the firmware to Merlin version, is it possible to manually configure dnsmasq thru telnet?
Not really. You can edit the config files but a restart of dnsmasq will overwrite them.
When i was playing around with flexqos on stock firmware I used
script_usbmount=
to add changes during boot. Worked fine.
script_usbmount=
But depending on what you're doing it can be unreliable as any changes could easily be wiped out at a later point in time.
Really want this feature to be introduced into the official firmware.
it is truly to install better version of AsusWRT - RMerlin.
you can ask Asus in 2014 for a 1y I was trying to get answer from them and I am still waiting :)
