Possible to download driver only for PCE-AC68?
psychopomp1
Hi
Does anyone know where you can download the latest standalone driver for the PCE-AC68? The Asus website only lists the utility software which has the driver embedded but i want to avoid any utility software aka bloatware.
Cheers
I haven't seen a download without the utility, but you don't have to use the utility once the driver is installed. Just disable it from starting up with your computer and you can use the OS wifi controls.
Thanks but how do i stop the utility from booting up? Its not listed under startup programs when i go to "msconfig".
A Is wireguard client on the AC86U possible? ASUS AC Routers & Adapters (Wi-Fi 5) 6
