Possible to rename USB attached drive?
Untried3868
Using a SATA drive in a Ugreen enclosure. I was wondering if it's possible to rename that drive without reformatting and setting all the scripts up again?
I tried searching (advanced search) SNBF but no results. Searched AMTM options as well with no luck.
TIA
The share name is important, not the drive name...
usually defined in smb.conf
TIA
Which specific "name" are you referring to? There are various names related to a USB drive depending on what you're looking at. Can you give an example of the name you want to change?
