YazFi possible yazfi UI bug
ugandy
On the 5GHz,
I set Guest network #2 to vpnclient2 and guest #3 to vpnclient 1.
after restart, they both show client 2 on the GUI.
but if I look at the yazfi text config file they are correctly set. so it looks like a gui issue?
thanks
hugo
Jack Yaz
Part of the Furniture
On the 5GHz,
thanks
hugo
they default to 2 when the config doesn't load - can you check for javascript errors in the browser console (via F12)
ugandy
the console only shows 3 entries:
- this page is in almost standards mode
- some cookies are miusing the recommended samesite attribute
- this page is in quirks mode. page layout may be impacted
no other errors
ugandy
in addition, guest #3 checkbox for redirect all to vpn won't stay checked. this does not happen for guest#2
both vpn client 1 and 2 are up and running
/jffs/addons/YazFi.d/config shows the correct config:
guest 5_2 : redirect to vpn true and use client 2
guest 5_3 : redirect to vpn true and use client 1
but the UI shows:
guest 5_3 : redirect to vpn false and use client 2
i'm using firefox 97 and see no javascript errors on F12 console
Jack Yaz
but the UI shows:
this is also similar to the config settings not applying fully
Jack Yaz
can you upload your full config file somewhere like pastebin and share a link please?
Jack Yaz
i can't repro this. noticed you're on the alpha, can you try dropping to 386.4 ?
ugandy
ah now you are asking me to get off the good juice! cannot. but i'll come back after the alpha is final :)
i'll even do a full factory reset and re install of all the scripts :)
ugandy
but i can confirm (traceroute) that traffic is going to the intended VPNs on each guest .
guest 5_1 -> vpn client 1
guest 5_2 -> vpn client 2
guest 5_3 -> vpn client 1
ugandy
on the UI all are correctly displayed except 5_3 (shows vpn redirect off)
ugandy
it might be the alpha. i don't remember seeing this issue on 386.4
SomeWhereOverTheRainBow
On the 5GHz,
thanks
hugo
Here is my post on the same issue
