PPPoE WAN Assign Manual DNS Setting Not Work
tzchen
2025 0607 update my problem is solved
let pppoe reconnect after Assign Manual DNS Setting
Wan DNS Sever priority can be Manual
from
server 1 : 168.95.192.1
server 2 : 168.95.1.1
to
server 1 : 168.95.1.1
server 2 : 168.95.192.1
Dear all
my router asus ax86u pro by merlin 3006.102.4
wan user pppoe by isp
wan defult dns get server from isp
i want my dns server 1 is 168.95.1.1 not 168.95.192.1
So Way1 not work
but it not worki ,till get
Internet status
use ssh nslookup server1 not 168.95.1.1
is 168.95.192.1
also if
server 2 : 8.8.8.8
it still get
Way2 it looks fine?
After WinSCP edit /tmp/etc/resolv.conf
dns server1 to 168.95.1.1
i know this modify will be clear after router reboot
need Help another good way or scripts
ps:
by a way ipv6 Manual DNS is ok
wan defult ipv6 dns get server from isp
server 1 : 2001:b000:168::2
server 2 : 2001:b000:168::1
setting
ipv6 dns Manual DNS
server 1 : 2001:b000:168::1
server 2 :2001:4860:4860::8888
In part because you have 2 DNS servers, the priority of which is decided by the router, not the user! What are you thinking being able to set the priority will do for your connection?
also if
server 2 : 8.8.8.8
it still get
168.95.192.1 Poor connection quality
setting
ipv6 dns Manual dns
