PPTP client default gateway
Andrii
Hi.
After making client PPTP session on my Asus RT-AC3200 the ppp interface making defaul gateway. But I need for default gateway stay my WAN connection. I can't found where is configuration file of pptp client on Merlin's firmware.
Can anybody help me fix this problem?
PS Sorry for my english :)
Hi.
Any body know how to configurate PPTP client on Merlin's firmware?
Hi.
PPTP is Point-to-Point, so the fact that the default route is via the PPTP interface is by design and attempts to provide basic access security.
NOTE: Unlike OpenVPN, there is no PPTP equivalent of the 'route-nopull' directive to automatically force the use of the WAN when the PPTP client interface is established.
Configuration of the outbound PPTP connection is via the PPTP Client GUI and the variables are actually stored in NVRAM and can be examined/modified from a command prompt:
nvam show | grep vpnc
vpnc_pppoe_ifname=ppp5
vpnc_ipaddr=10.200.21.5
vpnc_pppoe_username=
vpnc_pppoe_passwd=
vpnc_pptp_options_x_list=<+mppe-128
etc.
So if you wish to bring UP the PPTP client but then restore the default routing to the WAN then issue:
ip route delete default via xxx.xxx.xxx.xxx dev ppp5
but unless you now manually configure Selective Routing (aka Split Tunnelling) then I'm not sure what you expect this route deletion to achieve?
