PPTP how secure is it? Want to use iPhone to VPN to home network
bigup
I want to use my iPhone to VPN in to my home network
Im using latest merlin firmware and have read that pptp is unsecure
So what do I use? iPhone doesn't support openvpn and I cannot jailbreak my iPhone yet (ios6)
Any other options?
Thanks.
Risk tolerance and appetite is a difficult to gauge for another person, entity, or process without knowing the environment details.
Simply- How important is your data you are communicating over PPTP vpn?
Then, does PPTP provide sufficient protection to match up with how important you assess your data.
Currently PPTP is under scrutiny because of the level of protection afforded is relatively low compared to other VPN controls and there is the availability of automated tools which can be used to defeat the PPTP VPN controls.
(http://www.h-online.com/security/features/A-death-blow-for-PPTP-1716768.html)
R iPhone teather problems and fix Asuswrt-Merlin 0
