Hi Merlin, sorry to hear that, because the challenge here in New Zealand is that PPTP is 10 times faster than OpenVPN on all the VPN providers I have tested (I tested about 10). Is there no way we can run a script or so to apply policy based routing to L2TP (even faster) please?No, and there are no plan to implement it either. I consider PPTP to be legacy technology that people should avoid using if possible.
i am way too much of a noob to even consider that. But why is it that L2TP is so much faster than OpenVPN when OpenVPN is supposed to be the future?
similar issue: My VPN provider openvpn config file is using UDP. Unfortunately, my Middle Eastern ISP is blocking UDP ports.Hi,
Just want to know if its possible to apply policy based routing on a PPTP VPN connection within ASUSWRT-Merlin?
If not, maybe it should be implemented.
Thanks!
He's already answered that question in posts #2 and #4. Also here. It's a legacy feature that isn't worth dedicating the development time to.Can anyone help and highlight why Merlin is not actively working this issue: making policy rules also available for PPTP
Openvpn config files are TXT files called <something>.opvn , you should be able to edit the file and change the UDP to TCP.similar issue: My VPN provider openvpn config file is using UDP. Unfortunately, my Middle Eastern ISP is blocking UDP ports.
No openvpn config files with use of TCP are available, which is forcing me to go to PPTP, which has the limitation of no policy rule implementation in the Merlin firmware. Can anyone help and highlight why Merlin is not actively working this issue: making policy rules also available for PPTP
PPTP is fast, but it's very insecure on all aspects - from ciphering on content to authentication...
L2TP can be fast and secure, but L2TP by itself is just a Layer 2 Tunnel - what makes it secure is IPSec, which many implementations actually use...
L2TP is faster because it runs in kernel space as a driver/interface vs. OpenVPN which needs to make jumps between kernel space (the interface driver) and userland (the ovpn and opensssl tasks) and back to kernel. It's not elegant or fast, but it is portable, and that's the goal of the OpenVPN team.
There are other options - Wireguard and ZeroTier come to mind, but that's outside of the scope of AsusWRT and the variants...
Welcome To SNBForums
