ADFHogan
It's 2021... so Happy New Year.. and, well.. the USB stick I had in my router (Kogan Ultra 32GB) crapped itself.
Filesystem pretty much hosed, and with dmesg errors during attempted mount, reformat, and dd.
What USB sticks currently available are folks using for their routers with amtm installed plugins etc.?
So you can spot one in the future:
Bus 002 Device 016: ID 1f75:0918 Innostor Technology Corporation
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.10
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1f75 Innostor Technology Corporation
idProduct 0x0918
bcdDevice 2.10
iManufacturer 0
iProduct 3 STORAGE DEVICE
iSerial 4 XXXXXXXX
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x0020
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0x80
(Bus Powered)
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk-Only
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Binary Object Store Descriptor:
bLength 5
bDescriptorType 15
wTotalLength 0x0016
bNumDeviceCaps 2
USB 2.0 Extension Device Capability:
bLength 7
bDescriptorType 16
bDevCapabilityType 2
bmAttributes 0x00000006
BESL Link Power Management (LPM) Supported
SuperSpeed USB Device Capability:
bLength 10
bDescriptorType 16
bDevCapabilityType 3
bmAttributes 0x00
wSpeedsSupported 0x000e
Device can operate at Full Speed (12Mbps)
Device can operate at High Speed (480Mbps)
Device can operate at SuperSpeed (5Gbps)
bFunctionalitySupport 2
Lowest fully-functional device speed is High Speed (480Mbps)
bU1DevExitLat 10 micro seconds
bU2DevExitLat 2047 micro seconds
Device Status: 0x0000
(Bus Powered)
Witness the sheer bork...
[327315.349429] scsi_io_completion_action: 419 callbacks suppressed
[327315.349437] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.349443] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.349447] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.349452] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b1 10 00 00 f0 00
[327315.349455] print_req_error: 419 callbacks suppressed
[327315.349458] blk_update_request: critical target error, dev sda, sector 11907344 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.349464] buffer_io_error: 12841 callbacks suppressed
[327315.349466] Buffer I/O error on dev sda, logical block 1488418, lost async page write
[327315.349473] Buffer I/O error on dev sda, logical block 1488419, lost async page write
[327315.349476] Buffer I/O error on dev sda, logical block 1488420, lost async page write
[327315.349480] Buffer I/O error on dev sda, logical block 1488421, lost async page write
[327315.349483] Buffer I/O error on dev sda, logical block 1488422, lost async page write
[327315.349486] Buffer I/O error on dev sda, logical block 1488423, lost async page write
[327315.349493] Buffer I/O error on dev sda, logical block 1488424, lost async page write
[327315.349496] Buffer I/O error on dev sda, logical block 1488425, lost async page write
[327315.349499] Buffer I/O error on dev sda, logical block 1488426, lost async page write
[327315.349502] Buffer I/O error on dev sda, logical block 1488427, lost async page write
[327315.354558] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.354564] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.354568] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.354573] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b2 00 00 00 f0 00
[327315.354577] blk_update_request: critical target error, dev sda, sector 11907584 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.359528] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.359533] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.359537] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.359541] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b2 f0 00 00 f0 00
[327315.359546] blk_update_request: critical target error, dev sda, sector 11907824 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.364434] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.364440] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.364443] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.364535] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b3 e0 00 00 f0 00
[327315.364547] blk_update_request: critical target error, dev sda, sector 11908064 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.369126] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.369131] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.369136] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.369142] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b4 d0 00 00 f0 00
[327315.369146] blk_update_request: critical target error, dev sda, sector 11908304 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.373733] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.373736] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.373738] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.373741] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b5 c0 00 00 f0 00
[327315.373743] blk_update_request: critical target error, dev sda, sector 11908544 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.378394] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.378397] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.378399] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.378401] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b6 b0 00 00 f0 00
[327315.378404] blk_update_request: critical target error, dev sda, sector 11908784 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.383131] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.383133] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.383135] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.383138] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b7 a0 00 00 f0 00
[327315.383140] blk_update_request: critical target error, dev sda, sector 11909024 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.387623] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.387625] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.387627] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.387630] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b8 90 00 00 f0 00
[327315.387632] blk_update_request: critical target error, dev sda, sector 11909264 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
[327315.392429] sd 16:0:0:0: [sda] tag#0 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[327315.392434] sd 16:0:0:0: [sda] tag#0 Sense Key : Data Protect [current]
[327315.392439] sd 16:0:0:0: [sda] tag#0 Add. Sense: Write protected
[327315.392443] sd 16:0:0:0: [sda] tag#0 CDB: Write(10) 2a 00 00 b5 b9 80 00 00 f0 00
[327315.392448] blk_update_request: critical target error, dev sda, sector 11909504 op 0x1:(WRITE) flags 0x104000 phys_seg 30 prio class 0
