Print server on AiMesh node?
Mine Ong
hi all,
I am new to AiMesh so my problem may be trivial to some. I seek your help in setting up a print server on AiMesh node.
I have 2 AC68U (converted from TM-1900) and have set them up as AiMesh Router and Node respectively. One thing I noticed immediately is that I lose direct control of the Node: if I try to login to the WebUI of the node by its IP address, the web browser is redirected to the AiMesh Router instead.
I would like to set up a printer server on the Node: The AiMesh router will be located on the main floor where the in-coming Internet connection is, and the Node will be located at the office where the printer is. But since I cannot login to the Node via the web interface directly, how does one go about setting up a printer on the node?
any help/hint is very much appreciated,
