Printer in Guest Network...
OAM
Hi, I am a noob at this hence appreciate your patiene.
I have a Linksys EA6900 router running XWRT-Vortex (AsusWRT-Merlin port for Linksys). I have a wireless printer in the Guest wifi SSID (need this is guest network because my kids friends come over for studies and need access to printer). At the moment I cannot access this printer from by LAN. What do I need to change to access the printer from the systems on the LAN, but still maintain the Guest N/W isolation.
Many thanks in advance for help
OAM
You can't have both isolation and access.
You may be able to achieve this with VLAN's and scripting, but that will be for others to suggest.
Thank you L&LD. LoL! yes, Isolation and access are opposite poles, agreed. Pardon me for not being clear. I meant access from one direction ie LAN --> Guest N/E and isolation in other direction Guest N/W --> LAN.
Hoping to get more suggestions from others in the forum.
Simple and easiet and sure way. Get a cheap WiFi printer and connect it to Guest network for guests to use it. Guest device should have printer driver.
Hi OAM, I had exactly the same case you describe, this is how I solved it.
I'll let the most experienced guys in the forum to assess how secure this setup actually is.
  1. Create a new guest network without isolation (Access Intranet = on)
  2. Connect the Printer to this new guest network (it is now accessible from my main wireless network)
  3. Allow communication from/to the printer from the Guest Network using a firewall-start script:
#!/bin/sh
#Allow access to the printer from Guest Network
PRINTER=00:00:00:00:00:00
ebtables -I FORWARD -i wl0.2 -o wl0.1 -s $PRINTER -j ACCEPT
ebtables -I FORWARD -i wl0.1 -o wl0.2 -d $PRINTER -j ACCEPT
And additionally, I hid the SSID for this guest network used by the printer (does not add any security, but it just bothered me seeing it listed):
nvram set wl0.2_closed="1"
nvram commit
#!/bin/sh
nvram commit
As you note, hiding the ssid doesn't do anything for security and may actually hamper performance.
But, having Access Intranet=On doesn't need your script to have the printer available to all and even worse; it allows the guest devices have access to the rest of the network too with no restrictions.
#!/bin/sh
nvram commit
Thanks jmedaglia,
I was hoping there would be a firewall solution, and iptables entry. But wasn't sure how! Your response gives me some ideas. I don't want to remove Guest N/W isolation, but am hoping with correct rules it might work. I'll play around with this and if successful will post my solution back.
OAM
