Problem loading /mnt/RT-AC68/Traffic/tomato_cstats_1831bf4a20e0.gz. Still trying...
Khadanja
Dec 20 19:13:43 cstats[261]: Problem loading /mnt/RT-AC68/Traffic/tomato_cstats_1831bf4a20e0.gz. Still trying...
Why do I see this log? I had Web History turned on briefly but it is turned off now, not sure if related!
This is not tied to web history but to traffic monitoring.
The file could potentially be corrupted. Rename it, then go to Tools -> Other Settings, and select the option to create a new file.
Hi!
I have the same problem. I did follow the instructions above... Deleted the file, selected the option to create a new file in Tools. Problem has reappeared even though a new file has been created. And I can see monthly stats still. Maybe the message is being produced even though stats are being successfully retrieved and stored? Weird! Running 384.18.
Hi!
Check your USB drive for errors. It is possible to use the /jffs partition for traffic but a good USB2 thumb drive is the best choice.
Thanks @bbunge !
I am using an SSD drive and it gets checked at mount time. Should be fine. No SMART issues with it last time I checked with the PC.
