- I am running a web server and have set up port forwardings (WAN...Virtual Server / Port Forwarding) for 80 and 443.
- I have DDNS set up. The registered DNS name resolves to my ISP-assigned IP address.
- I am able to reach the web server from outside internet and also from the LAN, in both cases by using its DNS name.
- I used YazFi to create a guest subnet. One way to guest=yes, client isolation=no. Machines on guest subnet can reach the internet.
- The web server is on the guest subnet.
- From a machine on the guest subnet, I can reach the web server at its subnet IP address.
- From a machine on the guest subnet, the server's DNS name resolves to my ISP-assigned IP address.
- From a machine on the guest subnet, I CANNOT reach the web server using its DNS name nor my ISP-assigned IP address: Connection timed out.
Thanks,
-Steve
