Hi all,
I have a problem with Dual WAN on my ASUS RT-AC88U.
I have Merlin 384.19 installed. Recently I just add another internet connection into my home cause I'm interested in using the Dual WAN feature on RT-AC88U.
My previous connection has 45Mbps speed. The new connection has 75Mbps speed.
I tried to setup Dual WAN Load Balancing, with both WAN on PPPoE. But no matter port I tried, port WAN always has trouble connecting to PPPoE.
The error message is Timeout waiting for PADO packets.
I tried :
Primary WAN = WAN & Secondary WAN = LAN 1
Primary WAN = WAN & Secondary WAN = LAN 2
Primary WAN = WAN & Secondary WAN = LAN 3
Primary WAN = WAN & Secondary WAN = LAN 4
Primary WAN = LAN 1 & Secondary WAN = WAN
Primary WAN = LAN 2 & Secondary WAN = WAN
Primary WAN = LAN 3 & Secondary WAN = WAN
Primary WAN = LAN 4 & Secondary WAN = WAN
But like I said before, the WAN port always shows Timeout waiting for PADO packets. I even switched the internet source, but still the error message from WAN port is Timeout waiting for PADO packets, no matter the source of the internet is.
But when I disable Dual WAN mode, it goes back to normal, the WAN port works normally without problem.
In my router, I installed Diversion, Skynet, and DNSCrypt.
Hopefully someone can help.
Thanks a lot.
I tried :
Thanks a lot.
