sn4k3
Hello,
ASUS AC66U
Firmware: 380.65_4
Internet ISP: Vodafone Fiber
Automatic IP from ONT
From yesterday to now my internet stop work after x minutes. And the only change i have done to router was set manual DNS to IPv6 section (No firmware update, no other change, before this always work well). After that i start to experience that problem with internet, so i tought it was from the setting so i revert to AUTO assign (Default). But for my surprise it keep happening, internet stop work after some minutes, less than 1 hour, i can say its about 30m to 40m but is not always at same time.
I have done a backup and have restore router to defaults and just config the internet, nothing more. Same happen...
I tryed to reset all equipments, same happen.
Router internet status says Connected and have IP but if i try to ping it fails.
Wifi and eth have same behaviour. If i shutdown all connected devices to router and turn on after 1h they will not have internet connection. So the problem may be within router?
The only thing that fix the problem is reboot router OR turn off and on internet connection, OR change other easy setting like DHCP query frequency, if i change from Aggressive to Normal OR vice versa the equipement instantly get connection again to the internet. So what i notice so far is WAN need to refresh or something like that? My WAN Lease Time is 1h
Can i write a script to auto change DHCP Query Frenquency every 20m and keep looping?
EDIT 1: I can ping WAN IP but not GATEWAY IP when this happen
EDIT 2: I don't need to change any setting on WAN tab to get internet again, just click Apply without change anything works too
Anyone have this inssue before?
Regards
ASUS AC66U
Firmware: 380.65_4
Regards
