Problem with Syslog in Asus AX110000
S.A
Hi.
I am trying to set the addresses of my computer that will receive the Logs from the router.
I set up the computer's IP addresses in Ssylog, I checked via Telnet that my computer is listening to 514 in UDP and indeed this is the case.
For some reason the router does not send the logs to Syslog.
I have an Aruba switch from which the logs do come to Syslog.
Is such a problem known?
I have an Asus AX11000 router, latest version 386.3_2.
ColinTaylor
Part of the Furniture
Remote syslog works fine in 386.3_2 in my experience. I suppose it's possible that there's a bug that's specific to the AX11000 but it seems unlikely.
I set up the computer's IP addresses in Ssylog,...
I assume that's a typo as you can only specify one remote syslog server address.
... I checked via Telnet that my computer is listening to 514 in UDP and indeed this is the case.
I thought Telnet was TCP-only?
It's probably best to ask questions in the dedicated Merlin forum when running his firmware as there may be differences from stock.
