Problems with internet after firmware update rt-ac87U
arealsou
Hello
Here is my problem, after last firware update ASUS RT-AC87U Firmware version 3.0.0.4.380.7378, my ac87u just disconnects internet (iptv stills ok), in the main board it says that internet is connected.
Tried to rool back firmware and the problem still persists.
One odd thing is when I select the tab wan and make apply the router reconnects and it stays connect for an hour ou two.
Is anyone who has the same issue?
reset to factory default and config all manually.
I've done the first part, no the second one, because the router has the vodafone settings on the lan iptv, and that part is automatic.
I'll try that later and tell how it goes.
No the problem persists.
As you can see the router says It's connected and no it's not, then I go to the wan tab and click in apply.
there is another problem the logs keep logging "miniupnpd[834]: shutting down MiniUPnPd"
At this time I'cve updated the Firmware Version:3.0.0.4.380_4180.
