Solved Project: Block Windows program from phoning home...
OzarkEdge
Part of the Furniture
How can I go about blocking a Windows program from accessing its/my cloud account? I want it to simply fail as though the Internet is temporarily unavailable. And I want to be able to easily allow access when I need it (infrequently). The program is unusable these days unless it is in a logged in state. Once logged in, it remains usable if I pull the Ethernet cable, so how to simulate/toggle that without actually disabling my network connection.
OE
How about creating a Windows Firewall outbound rule?
Old dog learning new tricks here. I set an outbound rule in Windows 10 Defender Firewall and that seems to work as desired without the program getting all upset about it. Thanks for the direction!
OE
How about storing all of that in a 2nd HDD in your main PC instead?
Sorry, I don't understand your meaning. I do have a 2nd internal HDD for daily backup.
OE
Then why are "storing" any material, private or otherwise thousands of miles away that has questionable security??
I'm also confused. Nobody said anything about "storing material". This is a fairly old thread so I suspect you've accidentally replied to the wrong thread.
OzarkEdge Solved Project: Block ads for all network users... General Network Security 11
