[Q] AC68U pptp can't connect samba
ryu2964
here is my setting:
pptp enable
lan broadcast both
MPPE check
auto dns check
auto wins check
mru 1450
mtu 1450
client 192.168.1.80-89 (dhcp range 192.168.1.100-254)
enable VPN+DHCP connection yes
network place samba support yes
i can use this setting surf internet and the vpn client(android phone via 3g) ip show my adsl's ip.
use my phone ping 192.168.1.1 & 192.168.1.101(my pc ) is work. and PC ping 192.168.1.80 also work. but I just can't access my pc via samba.
windows firewall was disable , I can access pc via wifi even use wifi connect this vpn server. its really weird.
p.s. I can access pc via 3g connect to vpn at tp-link wr1043nd-DDWRT (now change to ac68u). so it should be the router's problem.
can anyone give me some suggestion? thanks a lot!
if you wanna purchase a router which can automatically do Samba over VPN (PPTP or L2TP/IPSecure), then try googling punchvpn router. This router is based on Openwrt. It even has web based file upload/download via VPN for IPhone/Android in addition to samba.
All of your posts seem to be selling the punchvpn router.
Howbout just helping get the router they already have working?;)
