Qnap 231p2 vs synology 218play
AlexHaden
evening all
Been away from the NAS scence since dabbling with an LG nas a few years back, so looking to start again, small(ish) 2 bay NAS
Use is really only file storage, music shares for sonos, and streaming my movie collection to various devices, not too worried about transcoding, as I tend to store my films in something most of my devices can play.
Need to be able to sync with one drive, not too worried about resilience/redundancy, I’ll also be backing up to a separate DAS I have on my PC.
Kind of bouncing between the qnap and synology here, about to pull the trigger on the qnap as i can expand in the future with its addons, plus I can upgrade the ram if I need to, so feels more flexible.
The synology 218play, has a 64 bit processor, that’s a bit slower - so that’s made me think, is it that much better?
The 218 can allegedly transcode 4K, and while I won’t use it, it’s a nice to have for the same price as the qnap 231p2
I’m useless at deciding, can anyone tip me one way or the other?
Or save up another 100£ and get the
QNAP TS-251B-2G?
evening all
Between the two choices, I would stick with my preferred QNAP. :) Even when it comes at a price disadvantage like it does here (from the prices I'm seeing locally).
I would normally recommend a 3 bay or more configuration but in this case, this QNAP with an 8GB RAM stick and the quad-core 1.7GHz CPU combination will be noticeably more responsive than the Synology which seems limited to 1GB RAM, even with a 64bit processor.
So, did you order your QNAP and RAM yet? :)
Lol, yes...the expandability sold it
Just ordered the 231p2.
Figure if I don’t need to spend another £100 on the 251, that’s a new iron wolf for my new Nas
Both are good choices - really comes down to user preference with the WebUI...
