QNAP switch QSW-M2108-2C vs Ethernet backhaul ZenWiFi AX (AT8)
Jirka
Good day,
please inform me how to set QNAP switch QSW-M2108-2C fw - 1.0.2 build 20210122 to work Ethernet backhaul between ZenWiFi AX (AT8), both have fw: - 9.0.0.4.386_41994. One is in access point (AP) mode / AiMesh router in AP mode and the other as AiMesh Node. Unfortunately, the Ethernet backhaul does not work via the QNAP switch. If I replace the QNAP switch with a regular TP-Link TL-SG105, everything is fine and the Ethernet backhaul will start normally.
Thank you in advance for the information.
follower
Good day,
QSW-M2108-2C: a managed switch
SG-105: an unmanaged switch
Have you run with factory default without any setup for QSW-M2108-2C ? Have you managed QSW-M2108-2C?
Jirka
Yes, the switch is on by default.
The only thing set on it is the aggregation of lines on port 7 and 8 for my NAS
Jirka
I just made another attempt and that was to replace the TP-Link TL-SG105 switch with the QNAP QSW-1105-5T switch. Both are unmanaged switches. I got to the same problem as with the QSW-M2108-2C switch. After the restart, the aimesh will start for about 10 seconds and then the AiMesh Node will disconnect as if it were losing its IP address.
So the verdict is as follows:
TP-Link SG-105 (unmanaged switch) - Ethernet backhaul works
QNAP QSW-M2108-2C (managed switch) - Ethernet backhaul does not work
QNAP QSW-1105-5T (unmanaged switch) - Ethernet backhaul does not work
ZenWiFi AX (AT8) on an obvious problem with QNAP switches.
Any advice?
