QoS settings won't stick (Voxel), effectively no QoS available.
Alex Kampas
Hello,
I have been using Voxel's excellent firmware and I am grateful for this.
The only problem I have (and I had the same issue with the stock firmware, regardless of version) is with QoS.
The main issue is that when I choose a priority for a connected device, set it and save, when I click again, it is set back to what it was (usually to low). As such I cannot change the priority which renders the whole point of QoS null.
Additionally, since after I installed Voxel's firmware, the router cannot do a speed test anymore. I click to start, and everything is greyd out.
Any help (mainly for the former issue) would be great. The problem is so large that when my server (whom I want at lowest priority) downloads files (cloud backups/restores) my Smart TV (which I want at highests) pauses playback from BBC iPlayer and only resumes if I stop the server. This should not be happening.
Thank you
Does this happen with different browsers? Try IE11, FF or Opera.
Try a factory reset on the router and setup from scratch. Still happen after this?
I am not sure regarding whole QoS but speed test is rather problem of OOKLA itself or NG:
https://community.netgear.com/t5/Ni...lt-In-QoS-Speed-Test-Not-Working/td-p/1675875
Above link is regarding stock firmware.
Voxel.
A firmware for XR500 was released that fixed the speedtest last week, so I imagine one will be pushed to the R7800 as well. It also included a fix for disconnections from Qualcomm, so I imagine that will be pushed to the R7800 too as its the same chipset.
