QTS 4.2.2 Build 20161028 - hotfix for FileStation bug
sfx2000
Part of the Furniture
QTS4.2
[Feature]
  • The WebDAV protocol has been removed from File Station remote connection due to usability concern when copying big files. And the original WebDAV connection will be removed after upgraded.
[Known issue]
Back up
  • The Container Station folder can only be backed up using Rsync when no containers are running. It is recommended to use the import/export feature in Container Station to back up containers.
Container Station
  • Setup default folder of Contrainer Station on a VJBOD shared folder and reboot VJBOD would cause Container Station crash. Container Station v1.6 will not support VJBOD and filter out all VJBOD shared folders.
[Bug fixes]
  • Fixed an issue where the interface of File Station would freeze when users attempted to access the folder where certain files were uploaded via Samba.
sfx2000 QTS 5.1.5.2645 build 20240116 QNAP 0
K QTS or QUTS Hero QNAP 1
O QTS admin access rights QNAP 6
