I have a question about AX and AC AiMesh mix.
When using AX router as AiMesh router and AC router as AiMesh node, would the AX router use 802.11ax standard? or the AX router would only use 802.11ac standard even if you enabled 802.11ax?
Early last year an ASUS engineer told me even if you use AX router with another AX router as AiMesh, both will be forced to use Wifi 5 instead of Wifi 6 no matter what settings you applied. I think this is fixed with Aimesh 2.0, but I don't know about AX + AC situation.
I don't have Wifi 6 devices yet so I don't think I can check it myself.
