dig part of your firmware (my router doesn't have the 3006 firmware) or are you using the Entware version (in which case it's an Entware question)?Yep ... it is in the entware/bin directory.I will need to look !!!
I just typed 'dig' as an option within unbound_manager and it ran !!!
What is in your .digrc file. I'll try it on my router.Yep ... it is in the entware/bin directory.
Just contains:What is in your .digrc file. I'll try it on my router.
-4
bind-dig package and reinstall it.T did run it from the command line and got the crash.Seems to work for me.
Try running dig from the command line instead of "within unbound_manager".
If it still fails I suggest you remove thebind-digpackage and reinstall it.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
