I finally upgraded my R66U router and stuck with Asus. I didn't initially update to Merlin, but did that after a day or 2 and everything seemed fine. I didn't reset to factory though.
I also decided to try the Smart Connect thing so I wouldn't have to decide which band to connect to. That also seemed to work great, with the exception of one client - a TCL Roku TV. On the old router it connected to the 5G band with no problems, however with the Smart Connect active it couldn't connect at all.
I could see it pop up on the router and sometimes get an IP assigned (or so the router thought), but it couldn't lock on. It was always popping up on one of the 5G bands. I ended up turning Smart Connect off and it connected instantly so that's where I left things.
Is this a common occurrence with Smart Connect and certain clients? Any workaround other than not using it? Really doesn't matter since everything works now, but I'm curious about it nonetheless.
