Question about squid or iptables (redirect)
rogern
I wonder if it is possible to install squid as i have an rt-ac3200 wich i think is strong enough to use squid/privoxy, i know it is only 256MB ram so i then wonder how to redirect 80/443 to a raspberrypi.
Maybe there is a better solution as i have on the raspberrypi a solution to filter https traffic.
iptables is not my thing though so i need some guidence if that`s gonna be the solution i go for.
How can you convert this so it works with my asus and firewall-start.sh ?
# Create an exception for the squid server:
iptables -t nat -A PREROUTING -p tcp -s 192.168.1.1 --dport 80 -j ACCEPT
# Redirect all other LAN requests:
iptables -t nat -A PREROUTING -p tcp -s 192.168.1.0/24 --dport 80 -j DNAT --to 192.168.1.1:8080
# Create an exception for root:
iptables -t nat -A OUTPUT -p tcp -m owner --uid-owner root --dport 80 -j ACCEPT
iptables -t nat -A OUTPUT -p tcp -m owner ! --uid-owner squid --dport 80 -j REDIRECT --to-port 8080
iptables -I OUTPUT -o eth1 -p tcp -s 127.0.0.1 -d 127.0.0.1 --dport 8080 -j ACCEPT
Remove .sh
