Question about the Adaptive QoS Tab
m33ts4k0z
Hello,
I'm using the RT-AC88U with 384.5 and everything works fine as usual. I'm having a maybe silly question though.
Since some versions ago, I noticed that the Adaptive QoS tab no longer shows the current network activity. I'm still able to see the activity by going to Traffic Analyzer but I like the Adaptive QoS meters better.
Note that I don't use Adaptive QoS but it used to work anyway before.
Is it supposed to be like that and show activity only when the Adaptive QoS is enabled or is it a bug?
thanks
I believe it has to "On" before it will display any activity. I assume you're talking about the first tab, "Bandwidth Monitor"?
Yeah exactly. I guessed so but before it wasnt necessairy for the QoS service to be on in order to display activity. I suppose it was bugged back then but not anymore. Thank you :)
