torstein
I know, yet another post about AiProtect. But I couldn't find a very clear answer to my question. I searched both this forum and google.
Does AiProtect add anything meaningful security-wise? I think not, here's why:
Intrusion prevention system:
Malicious site blocking:
Two way IPS:
Infected device prevention:
So is AiProtect adding anything of value? Or is it just redundant? Is the router already protecting you well enough? Is AiProtect like installing antivirus on Linux / macOS, i.e. technically increases the security, but completely pointless?
- If the Router is set up properly with disabled upnp, disabled port forwarding and port triggering, disabled web acccess from wan, disabled DMZ, disabled WPS, disabled Ping from WAN, disabled anonymous login to FTP share etc, the router is already as safe as can be, right?
- The firewall is blocking everything that my devices haven't requested anyways, and thus prevents intrusions. It is after all a SPI firewall.
- We already get that through Google safebrowsing built into our browsers and
- Ad-blockers such uBlock and Adguard for Chrome and FF, and Wipr for Safari etc
- ISP DNS or
- custom DNS such as NextDNS / Quad9 / OpenDNS / 1.1.1.1 etc
Two way IPS:
- Bitcoin mining is blocked by adblockers such as uBlock, AdGuard and DNS filters such as NextDNS and Quad9 for instance.
- Heartbleed and Shellshocked was patched in macOS / Windows / Linux and Asus firmware.
- DDoS attacks is taken care of by the router firewall and OS firewall (I think)
- Spam is taken care of by email services.
- The only thing of value would be blocking an infected device from calling home and being part of a botnet, but most likely you don't have an infected device, and with security patches and common sense when browsing, downloading and installing software etc macOS / Windows / Linux already takes care of that with OS updates and their own security measures.
- Same as above.
- As long as your OS is updated, router is updated and you dont install suspicious or pirated software, use keygens or look up shady sites / dark web or whatever, this is unecessary.
