Question and some help.
pinkfloyd1173
Hey you guys,
I have had an issue with the DSL Reports speedtest.
I use to own an AC3100 awhile back and now I have a AX88U. Well with the ac3100, when I run a speedtest I always got a bufferbloat grade, never had issues with it.
Now with the AX88U I can never get a bufferbloat grade?
I am not using QOS and everything is pretty much at stock settings.
I am however using the dumb switch method like I did when I had my ac3100.
I have tried to figure this out and also asked on their forums for some help, but nothing.
Maybe you guys can give me some advice on this.
Thanks in advance guys.
Here is the report from DSL reports.
0.00s Start testing Fiber
00.01s geo location failed
00.1s Servers available: 10
00.12s pinging 9 locations
05.12s 18ms Los Angeles 2, CA, USA
05.12s 24ms San Jose, USA
05.12s 38ms Beaverton, Oregon, USA
05.12s 46ms Houston, USA
05.12s 59ms Dallas, USA
05.12s 66ms Nashville, TN, USA
05.12s 71ms Newcastle, Delaware, USA
05.12s 72ms Westland, Michigan, USA
05.12s 76ms Silver Spring, MD, USA
05.13s WARNING could not assemble 32 streams with available or selected servers
05.13s 5 seconds measuring idle buffer bloat
07.16s Internet connection interrupted? - websocket error
10.3s Trial download normal
10.32s Using GET for upload testing
18.43s stream0 15.15 megabit San Jose, USA
18.43s stream1 59.34 megabit Los Angeles 2, CA, USA
18.43s stream2 132.5 megabit Los Angeles 2, CA, USA
18.43s stream3 18.1 megabit San Jose, USA
18.43s stream4 78.29 megabit Houston, USA
18.43s stream5 18 megabit San Jose, USA
18.43s stream6 1.07 megabit Beaverton, Oregon, USA
18.43s stream7 1.55 megabit Beaverton, Oregon, USA
18.43s stream8 14.56 megabit Los Angeles 2, CA, USA
18.43s stream9 13.72 megabit Los Angeles 2, CA, USA
18.43s stream10 16.26 megabit San Jose, USA
18.43s stream11 19.81 megabit San Jose, USA
18.43s stream12 11.25 megabit San Jose, USA
18.43s stream13 72.2 megabit Los Angeles 2, CA, USA
18.43s stream14 4.8 megabit Dallas, USA
18.43s stream15 3.06 megabit Beaverton, Oregon, USA
18.43s stream16 53.27 megabit Los Angeles 2, CA, USA
18.43s stream17 0.83 megabit Beaverton, Oregon, USA
18.43s stream18 1.43 megabit Beaverton, Oregon, USA
18.43s stream19 1.73 megabit Beaverton, Oregon, USA
18.43s stream20 86.46 megabit Houston, USA
18.43s stream21 66.75 megabit Houston, USA
18.43s stream22 48.45 megabit Houston, USA
18.43s stream23 30.41 megabit Houston, USA
18.43s stream24 47.92 megabit Houston, USA
18.43s stream25 3.94 megabit Dallas, USA
18.43s stream26 2.79 megabit Dallas, USA
18.43s stream27 3.03 megabit Dallas, USA
18.43s stream28 4.21 megabit Dallas, USA
18.43s stream29 3.98 megabit Dallas, USA
22.53s End of download testing. Starting upload in 2 seconds
24.53s Web socket to http://t49.dslreports.com are not working reading count =0
24.53s Using POST for upload testing
44.54s Upload report:
44.54s stream0 73.62 megabit San Jose, USA
44.54s stream1 22.66 megabit Los Angeles 2, CA, USA
44.54s stream2 38.95 megabit Los Angeles 2, CA, USA
44.54s stream3 164.14 megabit San Jose, USA
44.54s stream4 12.43 megabit Houston, USA
44.54s stream5 17.91 megabit San Jose, USA
44.54s stream6 21.7 megabit Beaverton, Oregon, USA
44.54s stream7 10.53 megabit Beaverton, Oregon, USA
44.54s stream8 32.42 megabit Los Angeles 2, CA, USA
44.54s stream9 433.98 megabit Los Angeles 2, CA, USA
44.54s stream10 33.12 megabit San Jose, USA
44.54s stream11 8.58 megabit San Jose, USA
44.54s stream12 4.38 megabit San Jose, USA
44.54s stream13 51.07 megabit Los Angeles 2, CA, USA
44.54s stream14 5.99 megabit Dallas, USA
44.54s stream15 14.53 megabit Beaverton, Oregon, USA
44.54s stream16 19.21 megabit Los Angeles 2, CA, USA
44.54s stream17 19.86 megabit Beaverton, Oregon, USA
44.54s stream18 12.76 megabit Beaverton, Oregon, USA
44.54s stream19 7.37 megabit Beaverton, Oregon, USA
44.54s stream20 62.77 megabit Houston, USA
44.54s stream21 16.72 megabit Houston, USA
44.54s stream22 6.64 megabit Houston, USA
44.54s stream23 12.71 megabit Houston, USA
44.54s stream24 46.48 megabit Houston, USA
44.54s stream25 6.62 megabit Dallas, USA
44.54s stream26 13.63 megabit Dallas, USA
44.54s stream27 3.95 megabit Dallas, USA
44.54s stream28 10.04 megabit Dallas, USA
44.54s stream29 7.31 megabit Dallas, USA
50.64s End of upload testing
50.65s Recording upload 982.7
50.65s Timer drops: frames=4 total ms=628 slip=0
50.65s END TEST
52.65s Total megabytes consumed: 4071.4 (down:1174 up:2897.5)
that's a server side issue. had a grade a few weeks ago, and since then I don't. I've also seen it before, some time last year. You could post a thread there to ask.
I've given up on DSL Reports as there have been many documented complaints recently. Ever try this one:
https://fast.com
No I have not tried that site. I think you are right about giving up on dsl reports.
Thanks for the info.
