[QUESTION] Android App. / Notify When IP stops pinging
sentinelvdx
I'm looking for an Android app which can ping ddns address every X interval of minutes, and push a notification if ping stops responding.
Just to monitor my Home network, if ISP goes down or router loss power I can know it and check what's going on.
If someone knows about one would you please share it here? Thanks!
Replied through TapaTalk
Something like this?
https://play.google.com/store/apps/details?id=com.overlook.android.whiz&hl=en
snip.......
Overlook
Keep an eye on your webservers (or any other TCP-enabled server) right from your phone home screen.
Whiz is a lightweight and smart service monitor in the form of a home screen widget, showing real-time state of your crucial servers and notifying you in case of outages.
Yes, thanks. But this one does not seems to work on jelly bean, I'm using now Ping HostMonitor app which is basically the same :)
