Question on Guests network ip range on AX86
GSpock
I have just activated 2 guest network on 2.4GHz and noticed that:
Guest 1 => clients get IP in the format of 192.168.101.x
Guest 2 and 3 => clients get IP in the format of 192.168.1.x which is the same range as my main router
Any idea why guest 1 has another way of configuring ?
Thanks,
GS
dave14305
Part of the Furniture
Guest Network 1 is shareable over AiMesh so it has to work differently than the others. If you want them the same, use 2 and 3 instead of 1 and 2.
GSpock
Thanks for your answer, I am not wanting anything special, I was just wondering.
