Question on router setup
sleeps1007
Currently I have the RT-AC5300 and I was thinking of buying an AX router to setup AiMesh. If I set the AC5300 as the main and the AX connected via AiMesh would I be able to get AX speeds with my AX devices if connected to the AX AiMesh?
L&LD
Part of the Furniture
Not likely. The AX router should be the main to have AX capabilities within its range.
If you're creating a wired backhaul AiMesh setup, you have a choice to make the AX router an "Access Point (AP) mode / AiMesh Router in AP mode", while still using the RT-AC5300 as the main. Giving you AX capabilities there too (within its range). If this also puts the RT-AX... (RT-AX88U or RT-AX86U highly recommended) in a central location, you may be able to turn off the radios of the main router too and have AX capabilities throughout the home (depending on size, construction type/materials, etc.).
sleeps1007
Interesting so if I setup the AX as the main and set the AC in AiMesh mode I will get the AX compatibilities? Also, what are your thoughts on the AX92U?
L&LD
