Question regarding inadyn
I want to update my IPV4+IPV6 using cloudflare
using this template works, but (of course) it's updating WAN IPV6
I need it to update specific client IPV6 (the one using 192.168.50.3 internal IPV4 ip)
what is the way to do it?
There's nothing specific to asuswrt about inadyn. You would get better support directly from inadyn folks.
FWIW, inadyn still doesn't support dual updates so if you want to update both ipv6 and ipv4 you need to run it twice with two different configs.
For simplicity, I use this script in /jffs/scripts/ddns-start which does the API calls that cloudflare needs under the hood. You have to set the variables used above this, but this is the meat of the script:
IP=$(ip -4 addr show dev eth0 scope global |awk '/inet / { print $2 }'|cut -d/ -f1)
TYPE=A
curl -X PATCH "https://api.cloudflare.com/client/v4/zones/$ZONEID/dns_records/$IP4_RECORDID" \
  -H "Authorization: Bearer $API_TOKEN" \
  -H "Content-Type: application/json" \
  --data "{\"type\":\"$TYPE\",\"name\":\"$RECORDNAME\",\"content\":\"$IP\",\"ttl\":"$TTL",\"proxied\":false}"
echo
IP=$(ip -6 addr show dev eth0 scope global permanent |awk '/inet6 / { print $2 }'|cut -d/ -f1)
TYPE=AAAA
curl -X PATCH "https://api.cloudflare.com/client/v4/zones/$ZONEID/dns_records/$IP6_RECORDID" \
echo
if [ $? -eq 0 ]; then
  /sbin/ddns_custom_updated 1
else
  /sbin/ddns_custom_updated 0
fi
TYPE=A
echo
TYPE=AAAA
echo
else
fi
Thats bastically something I was going to look into. With my dynv6, I have mine setup to do ipv6 and ipv4 separately.
I override the inadyn.conf with my own in /jffs/inadyn.conf
Obviously you would have to adapt this to your cloudflare setup, but it is doable if they have an update API similar to this. Adjust your setup accordingly
Thanks!
What part of the script is "calling" the specific client ipv6?
Does it matter that the client is macvlan client?
Mind Blown
This is my inadyn.conf for Cloudflare
ddns-start script will be the same as what @SomeWhereOverTheRainBow has mentioned
allow-ipv6 = true
provider cloudflare.com:1 {
     username = your_cloudflare_hostname
     password = your_cloudflare_api_key
     hostname = your_cloudflare_hostname
     checkip-command = "/bin/nvram get wan_ipaddr"
provider cloudflare.com:2 {
     checkip-command = "/bin/nvram get ipv6_wan_addr"
