[Question] Which adaptive QoS script is compatible 374 LTS version of Merlin?
  • ATTENTION! You'll notice a Prefix dropdown when you create a thread. If your post applies to one of the topics listed, please use that Prefix for your post. When browsing the thread list you can use the Prefix to filter the view.
lajcik
Hello,
I'm running the old RT-N16 router and successfully installed the 374 LTS version of Merlin - very happy with it. I've browsed a bunch of threads praising the custom adaptive QoS scripts floating around and wanted in on the party. However, it seems the recent CakeQoS and FlexQoS only support the newer firmware version so I can't use those.
FreshJR QoS does not state any version requirements so I went ahead and installed the latest version from here https://www.snbforums.com/threads/r...ements-custom-rules-and-inner-workings.36836/ but it doesn't seem to be working. I don't get the new tab in the webui, running FreshJR_QOS -debug shows a bunch of errors.
cat: can't open '/tmp/bwdpi/qosd.conf': No such file or directory
expr: non-numeric argument
The installation instructions were simple so I'm pretty sure I didn't screw up anywhere, but who knows...
Can anyone kindly point me to a version of one of the scripts that will work with the 374 LTS version of the firmware? Or am I out of luck and have to wrestle with the stock QoS?
john9527
Part of the Furniture
The LTS fork is traditional QoS only.....no adaptive. And the MIPS based routers never had adaptive on any asuswrt firmware.
lajcik
Thanks, that explains why my searching wasn't turning up anything.
I'm still not sure if FreshJR QoS does something or not tho - it makes a bunch of iptables entries but I can't tell if it actually does anything or not...
I guess I'll just experiment a bunch :)
dave14305
It’s creating rules to mark packets in a way that are of no use to Traditional QoS. So it’s better to uninstall it. John’s Traditional QoS implementation is very good if your download speeds don’t require HW acceleration.
